I dyed my first test piece but the color came out flat, after anodizing are you supposed to repolish the part to get polished color look? It had a powdery surface that rubbed off easily but still had color underneath. My dye was at room temp and dyed the piece fine. I then sealed in CASWELL sealer that was boiling.The color was CASWELL fast blue. The finish was flat but had good color that rubbed off easy but still had color underneath. The piece was scrap diamond plate (12"x6"x1/4") that was anodized at 6amps for 120 minutes at 14 volts. Can you repolish after anodizing before dying?
why flat finish
Re: why flat finish
You are probably seeing the effects of dissolution. Do a search on that word, there has been a lot of information and discussion posted on the subject that will be educational and help you to understand it, and hopefully learn what went wrong.
You can not polish anodized parts and dye them with success, once dissolution occurs the only remedy is to strip the part and try again. Of course, if you don't correct what went wrong in the first place, the problem will likely repeat.
Re: why flat finish
greetings Fragglerock,
If I may, can we take a couple steps back ---
to reconsider:
Does this particular color of blue have instructions different from Caswell's
other colors they sell? Because the dye should not be at room temp.
You should have it set b/t 130-140dg F.
Again, following a Caswell product instruction set-- this should not be
at boiling temp but instead at 90dg F.
I am very curious here-- You wrote "6 amps", but did you actually set your
CC at 3 amps as the 720 rule calculated? Following in line with the dissolution
suggestions proposed would point to an actual CC of 6 and not 3. But this
of course begs the next question; What size is your CC power supply? If
its the 3 amp model, ummmmmm. But if you own the 20amp model . . . .
Finally, I will add most diamond plate is of the polished kind from the manufacturer. But this is a very inferior Aluminum alloy when compared to
the traditional "aircraft" grades (6061-t6, 7075-t6, 2024-t3). You may find
a barrel of experimentation to bring this substrate to the likes of the 3
higher quality grades mentioned above.
Also I would not mix your diamond plate with any other grades.
archi
Re: why flat finish
archi,
Caswell offers two sealers for anodize. The standard nickle acetate is used at boil. The sealer LT is a reduced temp sealer that is not recommended for use with all colors of dye.
A part of 148.5" SA at a 6 ASF CD has a amperage setting of 6.19A. Run 120 minutes for a 1 mil coating with a projected peak voltage of 15V. The numbers jive for the run. The description given sounds like typical dissolution.
I didn't see anything on tank temp, agitation and acid concentration all of which can contribute highly to dissolution. The material grade can have a slight effect on it but is usually only a minor factor.
fragglerock,
Have you tried anything else or come to any conclusions?
SS
Re: why flat finish
thanks Sswee, for the catch.
yes--- the amp calculation is very close to the 6 amps stated.
Funny, after reviewing the dimensions I realized it mimics
Caswell's own rule of thumb:
for 1amp = 50sq" = 1 mil = 240'
1amp = 25sq" = 1 mil = 120' this is for a 6amp sq/ft base
Also to consider Fragglerock's results some more:
Given the diamond plate's material makeup I wonder if
he should hold the 6amp base and drop the anodizing time
25% (Mike C.'s comments in the "sticky" post).
Actually, I would drop the anodizing time by 1/2 and
review the results.
Sswee-- I have seen your putters done in the "fast blue".
Is that dye not brought to 130-140dg before use?
archi
Re: why flat finish
Sswee,
I run all my dye tanks at 140 degrees. Why do you ask?
It was part of Fragglerock's statement; ". . . the dye was at room temp." and
described the dye as "fast blue". I was curious about the temp. control of this dye. I was reviewing his operating parms and
this was one I thought was not in line with Caswell instructions. I have not used this dye myself.
The putters are half polished and half glass beaded.
Actually I did take a good look at your coloring and I liked the results!
The blue is very attractive--- I too have purchased some glass beads to
experiment with coloring results. I bought #12 size which is the finest grade
this particular company sold.
What size glass beads are you using?
archi
Re: why flat finish
archi,
I wondered if you used the same color and was getting a totally different look or shade. I have all the colors Caswell offers and run them at 140 degrees. I have heard of several people using the dyes at room temp. and Caswell tell them that they can't offer support for dye problems if they don't use the products according to manufacturers recommendations. Understandable I think.
Honestly I didn't check the last bag for size when I dumped it in the blaster. I buy mine from a large fab company that makes ship portals and hatches. A couple of things to watch with glass bead. If you blast with too much pressure, the surface texture will be rough enough that the part will have a alum. gray tint or shade through the dye color. The fix I use for this if it happens is to strip and etch. Then re anodize and it will give a nice even color. The other common problem is people don't go over the part enough to make sure the surface finish is truly even. After blasting the part will visually look good but after anodize you will be able to see where the focus of the blast went and the rest was not hit as hard. Kind of like scribbling with the blaster gun. I usually use 50 to 70 psi and always at a 45 degree angle. I've used glass bead primarily for years and prefer it to most other media I've tried.
SS
Re: why flat finish
From my experience, room temperature dye will not cause any imediate failures to the appearance. Heating the dye is best, but other than taking a bit longer to dye in some cases, and perhaps not holding the color as long in sunlight, etc., I haven't seen any obvious defects because of cold dye.
Re: why flat finish
my power supply is a used, Astron VS-35M, I turn on the power and ramp up the voltage to 14 volts and the amps gradually rose to 6. I did figure out one problem, the piece was to big to be completly submerged in the dye, so as I was dying the part the rinse water ran down the part into the dye, the part must be dry before putting into the dye
Re: why flat finish
just a quick add, the acid solution used was 1 gal NAPA auto parts battery acid to 3 gals distilled water, the temp was not registering on my thermometer so I guess it to be about 80 and the agitation is provided by the pump in the CASWELL kit and a water circulation pump for a fish tank
Re: why flat finish
fragglerock,
You need to figure a way to lower your tank temp. The higher the temp the more dissolution problems.
With that PS, did you keep your amps at 6A all during the run or did the amps go up then fall off?
The parts need to stay wet until after they are dyed.
SS
Re: why flat finish
Some thoughts come to mind:
I have had horrible desolution at temperatures over 72F. Tank temps need to be closely controlled.
You have calculated the run for a ful 1 mil coating. Desolution happens very near the end of a two-hour run at 6CD/70F/1:3 acid concentration. Try 1-12 hrs. for all colors other than black.
It sounds like you are not controlling the amps. Be sure to set the PS so that the amps are controlled, and not the volts.
Agitation... you have not mentioned what type (if any) agitation you use.I do things.
Re: why flat finish
I believe I have plenty of agitation as I use a air pump and a circ pump in the anodize tank, as for controlling the amps verses the voltage, how do you do that ? I anodized this part by setting the votage at 14 volts then turned up the amps to 6 amps, I did not adjust after that. At the start it was 6amps 14 volts, at the end of 2hrs it was 10amps 13 volts
