The Caswell manual recommends a post sealant treatment of anodized parts with WD-40. Why WD-40? As a firearms refinisher we do mostly gun parts. We NEVER use WD-40 on a firearm. When we finish a part with black oxide or parkerizing we use a water displacing oil (same as manufacturers) as a post treatment. Can this same product be used as a post anodizing treatment?
Post-sealing treatment
Re: Post-sealing treatment
Yes, you can use WD-40 or our Penetrating Sealer.
Many anodizers skip this process. It really depends on your preference.--
Originally posted by rick201Why do you use wd40 after the sealing treatment what are the benefits i may have to try it.
Does it make a better finish and do you soak it or spray on and buff off etc ?
Best Regards to all
Richard..
I get a rather dry chalky look on alot of pieces when I do not use oil like wd-40www.125customs.com - Quality custom anodizing for simple and complicated jobs.
