I am new to anodizing. I ordered some "pinch" racks and I am putting several different size parts on them. My question is what is the best way to figure out my area to apply the 720 rule. Example, the plate is 6" X 4" it may have 10 #2 screws, 2 hollow tubes 1/2 X 2 and several other parts of different sizes and shapes?
Area question
Re: Area question
It's best to be as close as possible but if your off 10 to 20%, it will not wreck everything.
6" x 4" = 24"sq. x 2 sides = 48"
1/2" x 2" tube = Pi x .5 = 1.57" x 2" = 3.14" x 2 (ID & OD) = 6.28" x 2pc = 12.56"
48" + 12.56" = 60.56" SA
This is rough since I don't know the thickness of the plate, wall thickness of the tubes, the length of the #2 screws or is it threaded holes for #2 screws. If you need help on how to figure SA, just let me know.
SS
Re: Area question
I can see where a simpler part could be done on grid paper but most the parts I have done with the amount of complexity as your sprocket mount I have had to sit down with a pad and pencil to trig the majority of it out to get a rough SA.
As far as dyeing there is no benefit for the thicker coating. As for durability, it will depend on how it is grown. I run at the bottom of the range on my tank temp and higher in the CD range to get a smaller pore size. I normally don't go past 1 to 1.2 mil on the coating.
SS
