I want to do some different anodizing effects but they are only mentioned briefly in the manual-is there any place online that has some walk throughs?
I also have some specefic questions-
How do some splashes and "sponge" effects and others that have an opaque color on top? I thought all the dyes were transparent, how would I go about recreating this.
Ive seen white in splashes on top of other colors- I thought you couldnt anodize white.
When dipping in dye it needs to stay there for several minutes and if I airbrush with the typical method the dye is aplied for a second and then it sees no more dye-does the airbrushing require mutiple passes for the dye to reach a dark rich color?
Thanks
Thanks
