Anodizing Dye - Light Fastness/Fading
  • Anodizing Dye - Light Fastness/Fading
    Do your dyes fade in outdoor applications? I will be using your blue dye(DYEB9), any special tricks/tips to miminize fading, such as, which sealant, room temp. or boiling is recommended.
    Thanks, Dan
    No, they won't fade.
    Just follow the instructions in the manual and you should get good results.
