mask it
  • mask it
    will the mask it protect bearings in the anodizing process? i have an aluminum piece that i want to do but there is a bearing machined into it that is not removable, or is there another product that could protect the bearing
    mask it
    I just use silicone.
    1966 Impala (hers)
    1966 Impala SS 427 (his)
    See them at
    The Watering Hole
      do you use silicone grease or rtv, i'd imagine the rtv would be tough to remove afterward
        Mask it should work fine for this application.
