What are the smallest anodizing/dye tanks that will work well? I'm only going to anodize a few small aluminum parts that are about 1 square inch or smaller. Can I get good results with a tank that's about a quart in size or should I go bigger? How about a 1/2 gallon tank?
Can the GP plate be cut in half or cut down to fit in a mason jar? It's just an aluminum plate, right?
Thanks,
Giffy
Thanks,
Giffy
