Im trying to plate a primary outer. I read the manual a dozen of times. I checked everything that i can think of . Temp.is around 110* and amp. I even went as far as ordering another batch of copy chrome thinking that the solution is a little weak. No matter what I do it seems that Im having to plate hours at a time. i only plate for 60 mins. then take it out. but even then you can tell that some areas thicker than others. i keep reactivating and plating. I bought the copychrome for the fact that its less toxic, and has more throwing power. I have cleaned my connects and including my clamps even went as far as shortening the length of my cables. the amperage on this part is only 12 amps for the whole peice. but it seems that it wont plate till i crank it to about 40 amp. but still take for ever.
SO WHAT AM I DOING WRONG!
