I have found over several plating runs, I've plated parts of my ceramic lined steel plating pot. Can you suggest a way to strip this nickel from the pot?
Stripping nickel from ceramic lined pot
The ceramic pot shouldn't plate. The fact that it did makes me think it's been damaged and the ceramic lining has been removed.
You might want to consider our improved system, which uses a plastic tank and a ceramic heater to get the solution to the correct temp. See http://www.caswellplating.com/kits/electroless.htm--
