Newbie Here
  • Newbie Here
    I have managed to use the Plug and Plate Copy Chrome kit succesfully and will post pictures later. Plating hood and door strikers, I need to add more solution, does this affect the solution that I already have used if I just add more to it? Strikers take alot of abuse, will it peel off as because the plating is so thin?
    You can just add more to the existing solution.
    I'm not sure if the plating on strikers will hold up for long.
