Hi!! I want to plate some circuit board lines (copper) with nickel. I have read that etching for 30 seconds in muriatic acid will clean and give a better surface for plate. What does the muriatic acid do for the prep process and does it clean the surface. Thanks --Phil
Muriatic acid??
It shouldn't be neceassary to etch with acid to plate nickel over copper. Just be sure the base metal is grease free (hot water and detergent or SP Cleaner)--
