after buying the triple plating kit, what other products....
  • after buying the triple plating kit, what other products....
    After purchasing the 4.5 triple plating kit, assuming I have nothing here. What buffing equipment, stripping solution and what not will I need to successfully complete a chroming project? Thanks for your answer it will help to determine what I need to purchase from you.
    Waiting on an answer...
    I know I am impatient, but if I am to spend a lot of money especially big money if I get a business going, its understandable.
    What other products will be needed?
    Thanks again
      That depends on what metals you are trying to plate.
      I suggest using our Pick-A-Buff helper at http://www.caswellplating.com to determine which buffing products you will need.
      If you're plating aluminum, you will need Zincate.
      You will need some battery acid and some muriatic acid and quite a lot of distilled water, and of course a power supply.
