Copychrome
  • lloyd
    copychrome
    Thanks again for another prompt reply. I will probably go for the Bright Copper Kit.
    ******* Inc Founder
    You can simply plate the item for longer to get a thicker plate. Flash Copper won't plate a bright copper plate though.
    Just top up your Copy Chrome with Distilled Water to the liquid level mark you marked when you first made the solution.
  • lloyd
    started a topic Copychrome
    Copychrome
    Finally got my copychrome set up and plated a few parts, and I have to say I am extermely happy at the results. Every thing I did came out near perfect. I would recomend your product very highly, thank you. I will take some pictures and send them to you shortly. Also, I would like to purchase the flash copper kit. Would I be able to plate 2 or 3 times to get some fill so I wouldn't have to get the acid copper kit? Also when I need to replenish the copychrome solution do I just add distilled water? Thanks in advance. Lloyd
