EPA law's
  • elboriqua
    epa
    Thank's For the replay. will it mater how long it will sit bofore Im abell to tap of? any corcern of contamination?
    The kit uses hexavalent chrome. The EPA is concerned mostly about waste water generation. If you use our system of rinsing your parts in seperate rinse tanks, then pouring the rinse water back into the corresponding tank when it needs topping up, you won't generate any wastewater.
  • elboriqua
    started a topic EPA law's
    EPA law's
    Im planing to get the sixteen gal. treeple chrome kit and the anodizing kit, I wold like to know if I should be corcern with epa, I live in a comunity where you can't do mouch with out some one complaining. next is are this kit consider trivalant chromium or hexavalent chromium? Please advice.
