nickel plating on a shaft
  • nickel plating on a shaft
    i have a shaft from an old motorcycle transmission that has a little wear on it and i would like to brush plate it with nickel to build it up a few thou....the problem is oil...how do i get the shaft degreased enough so the plate will stick?...someone mentioned a hot alkaline bath but i'm not sure what that is...anyone have any ideas?...thanks in advance
