What are the difference between Chrome and Chromate?
  • What are the difference between Chrome and Chromate?
    Good day, I'm confusing with what are the difference between Chrome plating and Chromate plating? It would be great to share what are both functions, materials and how to differentiate from the surface, thanks in advance
    Hi Justin,
    Chromate is a top coat that is put on zinc plated items to deter the zinc from white rusting. Chrome plating is a completely different finish, the steel is nickel plated then chrome plated.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Hi Jason,<br />
      <br />
      Thanks for the answer, so shall I assume that Chormate is majority for anti white rusting or any natural rusting and Chrome plating is majority for brightening? And both are the 2nd process after zinc / nickel process completed?
        No, the Chromate is only for Zinc, The Chrome would be used over Nickel.
        Jason Vanderbroek
        315 946 1213 x116
          Loud and clear, sincerely appreciate for your details explanation, thanks again!
