Zinc Plating surface brightness is not even
  • Zinc Plating surface brightness is not even
    Hi mates, currently I'm facing a critical issue regarding Zinc Plating surface brightness is not balance, the edge surface area is more bright if compared with the inner surface area, may I know what shall I do to make it balance?
    Bright plate on high areas only can be a couple things. 1) insufficient brightener. 2) insufficient current.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
