copper barrel plating over pewter
  • copper barrel plating over pewter
    Hi all,
    I have built a small barrel plater to copper plate small 3/4 inch pewter tokens. I am using an acid copper plate solution, but i can't get the copper to stay attached to the token. It just peels off. Any suggestions on how to prep the tokens or anything else that might help?
    Thanks
    Joe
    What steps are you taking to prepare the pewter for plating ?
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      sanding and rinsing in tap water.
        by the way, the solution is sulfuric acid, not cyanide.
          Hi guys. I am a new member to this forum. Nice to meet you all here. Looking forward to have a great time.
