Any idea why this piece was thinner after plating?
  • Any idea why this piece was thinner after plating?
    Hey Guys,
    I dropped off a few motorcycle parts to be chrome plated and one small piece came back with at least 50% less material than when it was dropped off. This is the first time that I had pieces replated and I'm just wondering what could've possibly caused this.
    Being a sucker and stubborn at the same time, I'm planning on buying a used replacement piece and have it plated again. But before I do, I'd like to hear from you guys about why this might of happened and if I could or should expect it to happen again.
    I attached two photos to show the before and after states. It's now at least half as thin as when I dropped it off and it's easy to see how much material is missing when viewed from above.
    Is it just not possible to do a piece this small or could the type of metal be a problem? I'm assuming it's just stamped steel.
    Thanks for reading,
    Bob
    The piece on the right is before plating This is the piece after plating
