bright acid copper plating - excess copper on anodes
  • bright acid copper plating - excess copper on anodes
    Hi there,
    I have just started using the bright acid copper plating kit from Caswell.
    I’ve noticed that when I take the anodes out at the end of a plating session, there is a lot of dissolved copper that runs off them - some gets into the solution before I rinse it off under the tap. I’m concerned that this shouldn’t be happening as surely having excess copper floating around in the solution isn’t good?
    Any advice much appreciated - thank you!
    Michaela
    Are you using anode bandages during plating ?
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Hi there, no I’m not, I was advised that I didn’t really need them...?
