Hi there,
I have the bright acid copper plating kit from caswell. I got my brass tank bars plated in nickel as per suggestion in the manual to reduce corrosion. They are still corroding a lot - as they are fixed into the tank (as per my university’s safety requirements) they are very hard to clean without contaminating the solution. Is it possible to use stainless steel bars to avoid the corrosion issue?
Many thanks,
Micha
Many thanks,
Micha
