charcoal filtering - acid copper solution
  • charcoal filtering - acid copper solution
    Hi there, I have the caswell bright acid copper electroplating kit. I have done a charcoal filtering process of the solution to try and cleanse it. Will I now need to replenish it with both the makeup solution and the brightener solution, or just the brightener?
    Thanks!
