rough, striated copper plate
  • rough, striated copper plate
    I have a 12 litre caswell bright acid copper electroplating kit. I was getting a rough plate so filtered with activated charcoal for 7 hours then did some dummy plating after adding back some brightener solution. This is now the result I am getting. Does anyone recognise this result and know how I might rectify it? Do I need to replenish the make up solution too?
    Many thanks.
    Is this the Dummy plates in the Photos ? If so then this is correct.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Hi Jason, yes the photos show the dummy plate - so I need more make up solution as well as brighteners?
