Zinc plating pieces attached to larger components?
  • Zinc plating pieces attached to larger components?
    Hello, I am working on some intake plenums which are cast aluminum and have pressed in tubes for vacuum sources. The original yellow zinc is corroded and they cannot be pulled out without damaging. How would I go about playing these pieces? Could suspend them into the bath or will the cast aluminum be harmed from this? Thanks all
    I would use the Mask-it to mask off the aluminum and it should be fine.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Is Mask-it a product on your website? I’m guessing it can be submerged into the plating tank and will protect the aluminum.
        I found it on your website, very cool, to be exactly what I need. Thank you Jason
