Problems, zinc plating
  • Problems, zinc plating
    Hey guys.
    Im very fustrated because i cant get my zinc plating to work.
    No matter how good i clean the part or how smooth and shiny i get it before i put it in the plating tank the result is allways the same dull grey finish.
    I have tried more heat in the soloution, more ageitation, clean the anodes, clean the parts in different ways such as vapor honing, bead blasting, wire wheel nothing changes the result. also tried adding more brightner
    This part i have calculated the surface area to be. 2,9cm3 and should be around 1,2AMPs.
    next i cleaned it with a scotch brite wheel so it was shiny, dipped it in to the supplied degreaser next 5 sec pickle in the muriatic acid, then to a clean bucket of water, next it the zinc bath.
    where i put it in for 25 minuts where i moved it every 5 minuts.
    Hope somebody can help me before i throw this kit out the window..
    Best regards Mathias.
    What is the Base Metal ?
    Was the piece previously Zinc plated ?
    Are you using our kit ?
    How many Volts are you using ?
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Hello Jason.
      The metal in the picture was copper. but its the same result with iron bolts.
      Yes some of my pieces has previously been plated but i have tried bathing them in muriatic acid until they stopped fizzing then vaporblasted them.
      Yes your kit bought via caswell europe
      I can´t turn the volts up or down on my powersupply. it just says 0.
        If you can not adjust your power supply then that would most likely be the cause of the issue.
        Jason Vanderbroek
        315 946 1213 x116
          I can adjust the amps but the volts always stays on 0
            Then I would assume there is an issue with the power supply that is causing the plating problem.
            Jason Vanderbroek
            315 946 1213 x116
              I have tried to different with same result..
