Will the positive bubble any when making nickel plat solution.
  • Will the positive bubble any when making nickel plat solution.
    This is my first time making nickel solution for nickel brass electroplating. I have it all set up and going, but the positive and negative are forming bubbles. The negative is forming a lot more bubbles than the positive like it should, but there are bubbles slowly forming on the positive. Is this normal?
