What to use for holding small filter pumps in place?
  • What to use for holding small filter pumps in place?
    Can neodymium magnets be used in copy cad solution, if not bare, will the epoxy coated ones work? It's very annoying to be mid plate and have the filter pump pop off because suction cups don't work well in the solution.
    I understand that an external pump and drilled pcv works well but this is for the smaller setups and for filtering.
    Asking for LCD anodize as well.
