Rookie. How to Zinc plate
  • Rookie. How to Zinc plate
    Hey guys have just got my electroplate kit. Am ready through the Caswell manual. Now I still need to get a few things before I start. I have a few questions. In step 6 says optional acid etch with 5% hydrochloric acid. Why is this step optinal? And also I read earlier in the book about pickle #4 can I use this rather then the hydrochloric acid ?
    and after this step should I rinse in distilled water before plating ?
    thanks for your time.
    Hey guys have just got my electroplate kit. Am ready through the Caswell manual. Now I still need to get a few things before I start. I have a few questions. In step 6 says optional acid etch with 5% hydrochloric acid. Why is this step optinal?I don't know the steps, is this after plating? If so it can help with chromate adhesion.
    and after this step should I rinse in distilled water before plating ? I personally use Muriatic acid, yes you rinse.
      Ok so do use dip in acid then plate then dip in acid again before chromate ?
        I’m also struggling to find the most efficient way to clean paint and rust off the bottles before plating them. Was thinking of buys a tumbler or maybe a small sand blasting cabinet or just using acid ? Would love to know peoples point of view
          Yes, it's certainly an option.
          I tumble everything before plate, wet (distilled water) with a rust cutting media. Then acid dip.
          I'm sure blasting can be just as effective.
