HELP! Questions about electroplating on plastic
  • HELP! Questions about electroplating on plastic
    Hi there,
    i am a sculptor looking for help with electroplating plastic parts. I am making plastic parts from silicone molds, and was wondering if certain plastics would be more compatible for plating. Ideally, the plastic parts will be made out of an epoxy resin clay. They could also be cast in a urethane resin. I am going to have the pieces nickel plated. I’d appreciate any help or tips on this matter!
    Thanks!
    take a look at our new 3D kit, this should also work fine for the type of plastics you are using also. https://www.caswellplating.com/3d-pa...ating-kit.html
    Jason Vanderbroek
    315 946 1213 x116
