Life of Zinc plating solution - how many parts can you plate?
  • Life of Zinc plating solution - how many parts can you plate?
    I purchased a 3 gallon kit of the zinc plating kit from Caswell with yellow Chromate about a month ago, after some initial trial and error I have been able to produce nice looking parts for the partial restoration I am doing, that is until today... apart from a couple of very small parts (less than 2-3 sq inch) the plating solution doesn't seem to be "taking". The larger parts are dull grey with darker areas which when scrubbed show the base metal and no zinc - I have filtered the solution, adjusted amperage, add brightener, but nothing appears to be changing the outcome.
    Again, my prep process is no different from when things were working. Is it possible that the plating solution is "used up"? I used the solution about 5-6 times have done a total of 20 small parts (5-10 sq inch) 15 larger parts (20-25 sq inch each) and quite a few blots and washers (80-100).
    Thx
    Franck
    Re: Life of Zinc plating solution - how many parts can you plate?
    Franck, I have a 1.5 gallon CopyCad system and have been using the same solution for over two years. I filter the solution through a paper coffee filter after every weekend of use and check the pH but have never had to adjust it.
    How are the wires used to hold the hardware plating? If the wires are accepting the zinc I would suspect another problem.
    That is about all the advice I can provide.
    Team FASTLIKEJUDY
      check the amperage that the pieces are taking from the rectifier. Maybe u have a bad connection...
      the first pieces u zinc... do u clean them?
      Thx
      Franck
        Same here. 2-3 hours and approx 20 parts plated beautifully then the zinc bath went south. Very disappointing after spending $600 to get going. Need a root cause and a fix to save the 3 gallons of solution...
          What has happened to your system ? can you give me some details or give me a call and we will make sure we get you back up and running. 315-946-1213 XT116
          Jason Vanderbroek
          315 946 1213 x116
          www.caswellplating.com
            I am having same problem. absolutly no difference in prep or set up. noticed I have to keep increasing amperage to get zink to plate. done very few parts then every couple I did noticed parts weren't gasing unless I increased power.
