Prospective CopyCAD buyer wanting someone to double check me
  • Prospective CopyCAD buyer wanting someone to double check me
    I am looking at buying the 4.5 Gallon CopyCAD system for zinc plating. The largest part I would probably have would be roughly 8.7" tall x 6.35" OD x 3.5" ID or 305 sq inches. The rectifier finder says I would need the Sku: RECT60 RECTIFIER - 60 AMP for this. Does this seem correct? Also, I need to Blue Chromate & Black Chromate finishes...How many bottles of each do I need? Is this just determined by the height of the part i.e. a 5 gallon bucket must be filled with 3 gallons of black solution to fully immerse the largest part, do I would need 3 bottles that make 1 gallon each?
    Correct on the Chromate, at 305 sq inches you will need almost 43 amps, so you will need a good size power supply.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
