Plug N’ Plate Silver Solution shelf life?
  • Plug N’ Plate Silver Solution shelf life?
    I called Caswell technical support and was told the shelf life for the Plug N’ Plate silver solution is 4 months? Does this sound correct?
    Also, I’d like to ask the forum if I can extend the shelf life by refrigerating or freezing?
    By shelf life, I’m referring to after initial opening and using the solution.
    4 Months is ABSOLUTELY correct. You may be able to prolong the life a few weeks by keeping it out of the light and stored in darkness.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
