I have two questions regarding the copy cad system.
1) From day one, the plating solution is a clear yellow until I agitate it. It’s like the A and B parts didn’t mix well. Should I use coffee filters to filter the solution?
2) Everything I have plated looks good except for a slight yellow color. I have added the brightener when I made up the first batch and once again after a few plating sessions. I can polish the parts lighly with a polishing pad on a Dremel. Could it still need more brightner? Thanks for any help.
