Plating voltage/current
  • Plating voltage/current
    What is the correct voltage and current level recommended for wand plating silver on copper? I have variable power supply that can be adjusted for voltage level and current limiting.
    hp
    Re: Plating voltage/current
    Volts should be between 4-10. The part will draw the required current itself.
      Thanks for the info. I will be trying out silver plating as soon as the plating solution arrives (silver on copper).
      hp
