My topic isn't right on point for this section but I'm thinking readers of this section have this topic closest to their interest. We'll see.
Background: Electroless Nickel plating (and it's variations).
I am interested in doing repair work as opposed to decorative work with EN & relative formulations. I must say I am ecstatic over my first attempts using the Caswell EN kit. After doing a few test runs on used parts, I managed to decrease the inner bore size of a couple of new ball bearings by plating a precise amount of EN that enabled "blueprint" specifications to be achieved on the crankshaft to inner race fit. After plating, I pressed the bearings on the crankshaft and then removed them. There was about a .0005" interference fit on a fair sized crank journal (this is a motorcycle in case you're wondering where the ball bearings come from) so the forces involved were substantial. After removal, there was no sign of flaking or scratching on either the EN or the crankshaft journal. I'm confident by this test that the EN is sufficiently hard and attached well enough that there should be no problems in rough service as a result of this repair method. Now I'm readying to raise the bar. So, I have a few questions regarding what I did already, and what I'm getting ready to do. Here goes:
1) My water break was lousy. Still, using a relatively fresh plating solution and following the specifications otherwise to the letter seems to have resulted in an aggressive attachment of the EN to the substrate. Since I was plating (relatively) clean, probably high alloy steel that had been oiled at the factory immediately after fabrication, I did not see the need to pickle. Also, I was somewhat worried about protecting the unplated regions of the part from the pickling as this has already become problematic anyway. What I did was to simply use lacquer thinner and brushed and scrubbed the target surface thoroughly then rinsed with DW. But, man, there still must have been a film there because it beaded water. Recommendations for a cleaner that will pass the water break in such an applications? SP degreaser? Remember, I'm having challenges with finding material that will mask off the non-target areas as well as resist the action of the cleaning activity. Also, why were my plating results apparently so good with a failed water break test? Lucky break?
2) I've been doing a lot of reading on EN. It would make me feel better to know what the phosphorus level of Caswell EN solutions are, i.e. high, medium or low phosphorus?
3) Next steps are to attempt professional repair of surfaces that slide or more particularly, roll against one another. Normally a hard chrome application but I think if nickel will withstand the rigors, it is a much better process to apply for these applications than is the chrome process. One reason is the uniform size control possible. There are others. One thing I could try is to harden the nickel by baking after plating. I'm also wondering, might not it be better to try Electroless Krome instead as the cobalt should make for a harder wear finish. What about ductility of Electroless Krome? Is it more likely to flake than EN? In this application I have in mind, the reground and plated shaft will actually be the inner bearing race and the rollers will be in direct rolling contact with it. Am I making myself clear here?
Well, I'll leave off here and see what kind of interest I've inspired in this topic.
Best regards,
Ed Clark
Best regards,
Ed Clark
