Silver Plating on Copper
  • Silver Plating on Copper
    I tried plating silver onto copper this weekend, and the results were not as expected. I must be doing something wrong. The setup I used is a 6 Volt DC power supply connected + to a 'fine silver' anode wrapped in gausse and dipped in PNPS12 Silver Plating solution. The copper pipe used for the test was first cleaned, and connected to the - terminal of the supply. The anode was brushed onto the copper, and drew about 1 to 1.5 amps from the power supply. The area turned black as the silver was deposited. After three or four minutes, I disconnected the supply and rinsed the pipe off in water. There was silver deposited on the pipe, but only a very thin layer. How long should it take to get 1 or 2 mils of silver deposited?
    I'm using a silver anode to increase the life of the plating solution. Would it work better with a stainless steel anode?
    hp
    Re: Plug n plate kit for bathroom faucets ?
    Sounds like too much power. It will work best with a silver anode, like you had.
    For further technical support related questions, we need you to use our PRS system so that we can properly track your problem. The PRS system is located at http://www.caswellplating.com/support.htm
    Thanks
