I was looking at your electroless nickel kits, and judging from the picture you're supply enamel plated cast iron pots.
I have some case panels (steel, approx 16 in sq) that I'm thinking about nickel plating and would like to go electroless.
What sort of requirements do I need to look for in order to find a suitable alternative to the pots you supply with the electroless kits?
