I'm in the process of plating some headlight rings from 46 Fords and Mercs.My problem is some of the rings are cast steel and the other ones are either stainless,copper or brass because after bead blasting ,using
Pickle #3 and de-plating to strip the chrome off I'm left with a copper or brass base(not sure).I polished this to a high shine.So how do i determine if these pieces are brass ,copper or stainless?
