Power source question
  • spectraflamed
    Re: Power source question
    Is that a car battery per plating level. For example would you need a battery for the copper level another battery for the nickel level etc.... Also can you hook up a car battery charger so that the battery does not run down?
    Usually a car battery or similar. Depending on the power requirements of the part of course.
  • spectraflamed
    started a topic Power source question
    I know your kits do not come with a power source what is generally used? at what cost? thanks
