Greetings
My main goal is to plate thru holes on pcb's. And I'm confused on which plating solution I should try. My holes are already conductive using something similar to silvaspray (if it was a Caswell product it'd probably be called silva~goop). I was leaning toward flash copper, but I really don't know what the difference is ~ when it comes to this type of application.
Thanks for your advice.
JT
JT
