Flash copper vs acid copper for PCB Holes
  • cdaw
    Ok did a lil more research, and unless you've magically pulled some new element from mars or somewhere , I don't want to go anywhere near electroless copper plating.
    I come to rest on the solution of silvering the holes. Which copper will directly plate to, and using pulsed power, with a periodic reverse, or masking everything but the holes ~ is very cost efficient , tired and true method. I don't have a need for "the black hole method" making 10 pcb's a week.
    I also have no need to directly plate plastic, or other non conductive material, But I do have possible uses for fattening pcb tracks from time to time, which electro will do fine.
    I read a bunch more and decided on Flash copper. My order has been placed
    Just for kicks - can you lend anymore info on your electroless plan, and expected time of availablility / cost.
  • cdaw
    hmm, another option.
    I always thought electroless was the less pro way of doing things, and that electro was the better option, or conversely - industry electoless/elctro process with 15 or so different dips, not something I want to do.
    I tried electroless tin and was incredibly unimpressed, so much so - that when I place my order for what ever copper solution , I'm getting the tin kit too.
    We are going to announce a new electroless copper system any day - so hang on!!!
    It is designed to plate directly onto plastic and PCB boards
  • cdaw
    started a topic Flash copper vs acid copper for PCB Holes
    Greetings
    My main goal is to plate thru holes on pcb's. And I'm confused on which plating solution I should try. My holes are already conductive using something similar to silvaspray (if it was a Caswell product it'd probably be called silva~goop). I was leaning toward flash copper, but I really don't know what the difference is ~ when it comes to this type of application.
    Thanks for your advice.
    JT
