I have a 1600 vulcan classic with a scratch on the chrome oil casing. I would like some help in smoothing out the scratch and to copy chrome it. I have never done anything like this before but am willing to try anything. thanks
Scratch repair
Re: Scratch repair
Hey wats up
ok first off you can not plate over chrome the chrome must be removed then the scratches
or scratch must be sanded/polished out (remember the best finish you start with is the best finish you will end up with) .Chrome Plate dose not cover scratches.
If you have any other questions about this process please feel free to contact meJim Eaton
Re: Scratch repair
Mike
The pnp is a great tool for small pieces but yes its just not economically feasible
if you can send me a pic of the part at [email protected] and I can tell you better what the best course of action would be but I believe the best ways are to sand or polish out the scratch or to fill it in with solder or weldLast edited by jimcarry; 09-08-2006, 08:37 AM.Jim Eaton
Re: Scratch repair
Mike
I have done some pieces on bumpers like extensions I have posted the on this site now they were scratched deep and we used a tig to fill them in. If your plan is to use the pnp take time to practice
I cant stress this enough and remember that no plate will stick to chrome so the area you are working with will have to be stripped just the chrome not the nickel or copper underneath another way to fill theses scratches would be silver solder or Caswell?s plum-loy there are also some other products in the Caswell?s catalog that you might look at .
Practice makes perfect
Hope I?ve been able to help
Good luckJim Eaton
Re: Scratch repair
I have been over the forum dozens of times searching for an answer to my dilema. I own a few vintage autos that have lots of little chrome parts on the engine not to mention the trim etc. I recently brush plated my chrome oil cap with the Caswell copy chrome brush plating kit. It worked very well, except there is an obvious line where the new chrome meets the old chrome. Anyway of making this transition a bit more seamless without the hassle of mask it etc.? Thanks!
Re: Scratch repair
Good luck
So what do you do with the solder? Do you just use it as a filler and polish it?
I have a nice problem I'm dealing with with my newly re-chromed bumper. I posted in the "metal polishing" forum.
