reading temps on tanks
  • reading temps on tanks
    Hi. Getting the last of my plating setup put together, and I was curious. You suggest a fish tank thermometer to check the tempratures of the various steps. Would an IR thermometer aimed at the liquid's surface also work? That way, it could also be used to measure the temp of the parts going into the solutions, and the one thermometer could be used without cross-contaminating the tanks. Thanks.
