ok this is a pretty novel idea that im sure no one has done before. well if you have then it would be great if you could tell me how it went. anyway a little background on the project.
computer cooling is essential when trying to overclock (run the computer faster than stock speed) and can be an interesting hobby. years ago, supercomputers were cooled by water. more recently, the average joe has started using water to cool the processor, northbridge, southbridge, hard drive, video card, or any combination of these. the conventional way to water cool is to make a copper waterblock, mount it on top of the processor and run water through it. silver is a better conductor of heat then copper, but the amount one would need is nearly cost prohibitive. another idea was running water directly over the top of the processor, but the cpu die, the part that generates heat, soaks up water over time and shorts out. lately people have been trying to make the baseplate of copper waterblocks thinner so that there will be less thermal resistance. hope you are still with me.
my idea is to silver plate (remember silver is better than copper at conducting heat) the die of a processor. the die has a non-conductive coating that would have to be sprayed with silvaspray. so i have some questions for the more experienced and knowledgable.
I am looking to get the thinnest layer of silver possible, any tips?
also, the top of the die appears to be perfectly smooth. if i spray it with silvaspray and am not worried about appearance of the finish, would it be necessary to do all the buffing and cleaning that is "99% of the process?" i worry that very much of that would damage the processor. im already dunking it in acid as it is lol.
final question, there is a sealant that is used to seal porous substrates. now how porous are we talking here? the top of a processor has no visible pits. however, it does apparently soak up water. do i need to seal it, or is porous more of a sponge-like reference?
thanks for the help. jungle
