Do you have to use pickle #3 when plating aluminum? is it really important?
AFter you zincate the aluminum do you go to flash copper or nickel? Which one is better? And after you do the flash copper do you need to go to bright copper or just right to the nickel. Im just going by what the manual tells me when i got the triple chrome kit.
Im trying to plate a Aluminum motorcycle(not a harley) brake caliaper bracket. I need all the help i can get. Thanks
