I am about to buy a recitier, and I am having some problems deciding on what to buy. My parts are small, but there are bigger ones to. I am going to use the copy chrome (its on the way) and I have parts between 15 and 30 square amps. And they are not all the same. My first question is, do I need it to be exact. Can I use 2 amps if the square inches is around 42 square inches, which would require 1.5. Not sure on how exact you need to be. Also, when I calculate the surface area, do I calculate the entire surface area, or just the area that is not masked off. Or, do I calculate the entire surface area if I am only doing the front. Please help me so I don't buy the wrong rectifier. I am going to need between 1 amp and 4 amps, and I want one rectifier to do the job, looks like I need two, which I don't want to do. I have spent enough money already.
thanks,
Kenny
thanks,
Kenny
