I want to plate a few putter heads (soft carbon steel) and I have a few questions.
1. What's the best way to remove old plating or paint.
2. I've read on this site that you need a strike layer of nickel BEFORE you plate copper. Elsewhere, i've heard of people plating putters with copper (soft) and plating nickel over it for durablility and finish. What should I do?
3. What kit should I use? I want to try the Plug-n-Plate first, but I'm wondering if I can dip the putter head into the solution?
THANKS!
THANKS!
