I have the small plug and plate system in both nickle and gold. My question is that I am trying to re do a firearm frame (1911 style 45) I have polished the base, electro plated it and re polished to a nice shine, the problem I am having is that there is still surface rust appearing and now I am not sure if I am doing it correctly. The frame is definately not stainless but I have no idea what type of metal is used in the manufacture of a firearm frame. The nickle appear to go onto the part, but I am wondering if when I am buffing the part for final finish if I am removing the initial nickle that was put on by the electro plate system? When I put the nickle on I get some areas that turn somewhat black, I am using a cloth polishing wheel and the red bars of compound on a 8" bench grinder. (the kit you buy from Sears to put on your bench grinder and it has 3 bars of compound red,black and white)
I suppose I am doing something wrong, so please just let me know...... dont worry.... I wont be offended by any suggestions or anyone telling me I did it wrong.
