Gents,
Here is the sitrep.
I have a piece with moderate amount of rust on it. It is a motorbike steering wheel which has been nickel and later chrome plated form the factory (no copper underlayer).
I removed the chrome plating along with all the rust. The surface now has a "camouflage" look on it with places where bare clean steel appears and other places where the surface is covered with the factory nickel. There was no way of preserving the old nickel in many places.
I activated the old nickel. I rinsed. Then dipped the piece in pickle #2. I rinsed again and then washed in degreaser. Then I started the flash copper process.
Initially, while the copper was still thin, I would still get a "camo" look with slightly different thicknesses. After a while, I achieved a nice thick uniform coat of flash copper. The copper appears to have a nice strong bond on both the clean metal and on the older, reactivated nickel. It does not buff off and it has a nice shine.
I am posting this more to get some opinions on the process and also if someone has had a similar situation to advise me about it. I might have overlooked something or done something wrong which might lead to (spontaneous ?) delamination later on.
The piece is about to get a coat of copy chrome.
Here is the sitrep.
