"Sandwiching" Acid Copper
  • "Sandwiching" Acid Copper
    Gents,
    I am using high-build acid copper over a flash copper strike. After I am done sanding down the acid copper, do I need to apply another layer of flash copper over the sanded-down acid copper layer (sandwich the acid copper between flash copper layers) or do I simply continue with the rest of the layers on top ?
    Copy Chrome is going to follow on top.
    Thanks,
    Ares
    no you dont need to add another layer of flash copper.
    bill
    http://home.comcast.net/~jhodges87/wsb/index.html
